Was wondering the best way to combine the 25A and 10A outputs into one fuse box for a total of 35A? Is this possible? I know GZ has a wiring harness to do this!
The best way is to use the 25 amp output by itself. The cigarette lighter socket is best suited for short term use as it will work loose after time and cause connection probs. The connectors that are made for the 25 amp output do not have this issue. I do not know if the outputs can be combined without damage though.
