→ If you have a way to check why data logging stopped dead for my unit on 2024/08/01 between 6:30 and 7:00 I’d greatly appreciate…
If it’s a bug in your system, could you try to fix it?
In any case, anything you could do to enable me restoring cloud logging from now, remotely?
As I explained I’m currently miles away from home, for another couple of weeks so power cycling it is NOT an option for me
Thanks in advance for your help
Hi @LLaurent , We want to fix this problem by upgrading the firmware.
Now I have applied to upgrade your system to our IT department. They will push the latest version of IOT to your machine in 24 hours.
Thank you for @Selfmadestrom 's kind help.
Hello @BLUETTI_CARE
I just returned from vacation and saw your message.
I’m in front of the machine, trying to upgrade, but I don’t get it how the new application works now with regards to upgrading the FW…
I am connecting via Bluetooth, of course, then I go to the information/version page. It tells me there is new firmware as you can see below, but then there is no button or anything obvious so I can actually trigger a firmware upgrade.(touching the blue cloud with arrow in it does not do anything).
Can you explain How this is supposed to work?
… and there I clicked this upgrade button, which finally got me to the same “New Version Available” page as before, but this time with clickable Upgrade buttons !
But @BLUETTI_CARE : this has been really painful … quite a struggle & non-obvious to reach out to the “really functional” upgrade menu…
By the way, why my session expired (does expire from time to time … not the first time it happens to me!) is incomprensible … why can’t the session keep active at all times ?
But now I hyave NEW PROBLEM : after session reconnection, my AC300 show offline although network and WiFi parameters were unchanged / are still OK
But my AC300 now looks offline although wifi and network connection display OK
and so I still cannot (I can no longer) access to the power/consumption/SoC status curves, which was my initial problem the FW upgrade was supposed to resolve
I tried signing-out / signing back in → same situation.
if you dont already do it, please upgrade the firmware, by connecting your unit by Bluetooth in the Bluetti App.
I had this strange behavior once myself. even after reconnect to the same wifi, still offline.
Please try the following, atleast it worked for me:
1.) Open a Wifi Hotspot/or change you wifi name temporary
2.) Go back in the Bluetti App and connect your unit to the “new wifi”
3.) Check if the status is online
4.) Change the Wifi Name as it was befoure/turn off you Hotspot
5.) Connect the Unit to the “old” Wifi and check if the problem persists.
Well … eventually the connection got restored without me doing anything special.
And data logging recommenced as well since around 9:30 this morning, that’s the time when I performed the FW upgrade.
Good then … but so strange !
Hi @gloksey, Yes, it is the correct IOT version.
Our technical department will push the latest version of firmware to your machine in 24 hours.
AC200L with currently latest FW and BMS versions also acted the same.
Before restart of device, WiFi was connected, live data through cloud connection was available, but logging of data has stopped. WiFi connection is stable and strong, but in rear cases it is manually restarted with no impact on data logging stopping.
Hi @kapsionu, Our new IOT v9041.10 firmware has optimized this issue.
Please provide the SN code of your AC200L so we can push this firmware update to you.
Hi @christobevii3, Our new IOT v9041.10 firmware has optimized this issue.
Our IT department will push the latest version of firmware to your machine in 1 working day. Please upgrade it tomorrow.
