Charging when grid voltage < 200
@BLUETTI can you please push firmware for my device too?
AC1802524001592056
Thanks in forward!
Hi @BLUETTI or @BLUETTI_CARE, I’m from Ukraine and experiencing frequent (Low Grid Voltage) errors on my EL100V2 due to unstable grid voltage (often around 180-200V because of the current situation). Standard firmware and Grid Self-adaptation don’t fully resolve it. Could you please provide a custom firmware with adjusted lower voltage thresholds?
Model: EL100V2 Serial Numbers: EL100V22525004117281
Current firmware versions (from BLUETTI app):
ARM v2186.09
DSP v2200.08
BMS v1083.07
Thank you for your support!
Hello, I have registered your device for a firmware upgrade. Please wait patiently.
The issue remains relevant for next device:
AC1802524001592056
ARM v2124.04
DSP v2126.03
Hello, @Bluetti_care. My AC180p refuses to charge at low electric current voltage. If the voltage is less than 190 Volts, the charging station does not charge even in quiet mode. Could you help with a new firmware that would solve this problem?
AC180P2349000831813
ARM 2089.04
DSP v2088.04
BMS v1039.01
@BLUETTI
Hi!
Please update my AC180 stations too
so they can charge at low voltage.
AC1802435005268945
AC1802433002019687
AC1802422000993707
AC1802435004959272
Thanks for your support.
Hi @BLUETTI adn @BLUETTI_CARE
Please push updated firmware to allow charging on low grid voltage for my AC200PL.
Today the grid voltage dropped to 195v and my ac200pl refused to charge, error e114/113. I tried everything from the suggested steps in troubleshooting - no luck. Seems it’s charging only when grid voltage above 200v.
SN: AC200PL2412000185472
IOT: v9041.06
ARM: v2140.04
DSP: v2130.09
BMS: v1056.02
Hi @BLUETTI or @BLUETTI_CARE, I’m from Ukraine and experiencing frequent (Low Grid Voltage) errors on my AC2P due to unstable grid voltage (often around 180-200V because of the current situation). Standard firmware and Grid Self-adaptation don’t fully resolve it. Could you please provide a custom firmware with adjusted lower voltage thresholds?
Model: AC2P Serial Numbers: AC2P2426000376423
ARM v2146.04
DSP v2136.01
IOT v9046.04
Hello @BLUETTI @BLUETTI_CARE , I have small ac2p unit, which is enough to cover my laptop. Unfortunately I can’t charge it regular way these days.
Low voltage error appears all the time. I usually have grid electricity for 1.5 hours between blackouts and can’t charge even half of battery. From the wall my Bluetti shows 175-185 volts and also shows 49.9hz.
Latest firmare, standard/slow charging, self adoptation does not help. Charging works fine via XT60, but that is very uncomfortable.
Can you, please, set lower input so I can charge it with my low quality grid voltage and also is it possible to set priority to charge from grid first and then from xt60?
Thanks in advance.
Model: AC2A
SN: AC2A2347006437555
ARM: v2084.09
DSP: v2101.02
Thank you for your inquiry. I will register the firmware update for you. Could you please let me know if you have enabled the grid adaptive mode?
If you have any questions, feel free to let me know.
Hello, I have registered your firmware upgrade. Please wait patiently.
@BLUETTI I don’t have an update for my charging station
Thanks for your help. I received the DSP firmware update v2136.60. The charging station charges at 188 volts. Thanks again.
I’m sorry, I will urge the technicians to help you. Please wait patiently.
Hey very thank you and all team for the update. Works great.
I wish setting for charging priority exists somewhere in the app, but for now I like that it has priority to charge from the grid instead of xt60.
As soon as grid appears, my 24v battery can charge itself without need to cover little bluetti use.
Also after DSP update I have no errors about low voltage even on turbo charging.
This kind of help shows who is the best on the market!
Hi @BLUETTI !
I have the same issue with charging my ac200pl in Ukraine when grid voltage is 175-190.
IoT2541117749433
AC200PL2542110156501
IoT v9041.11
ARM v2140.05
DSP v2130.13
Could you please help me with it?
Thanks!
