Charging when grid voltage < 200
Hi @BLUETTI !
It’s been ten days, I still have not a new firmware upgrade. I still have ARM v2053.08 and DSP v2052.11
Do I need to wait some more time?
Thanks in advance!
Hello, we have already sent you DSP211709. Have you not received it?
Are you forgot me?
Can you help me?
hello
still there is dsp 2130.13 and the app saying “You’re up to date”, connected via bluetooth.
When to expect the updated firmware?
No, I have DSP v2052.11 and “You’re up to date” in my Bluetti android application.
Hello, I have reported the issue to the technical team and they have pushed the firmware update again.
I apologize for not getting back to you sooner. I have now upgraded the firmware for you.
If you have any other questions or need further assistance, please feel free to let me know.
Thank you for your understanding!
Hello, please tell what problem you have encounter?
Thank you! I got the new firmware and it’s working!
10 days passed since my request @BLUETTI_CARE @BLUETTI
Thank you for your inquiry. The firmware is up to date. Please go to Settings - Advanced Settings - Grid Adaptive Mode, where you can adjust the parameters. Also, please ensure that your app is updated to the latest version.
If you have any other questions, please feel free to reach out.
As i mentioned earlier - i already tried everything that your Troubleshooting guide in the app suggests in case of low grid voltage, didn’t help. Are you sure the DSP: v2130.13 is the latest available firmware for 200PL model and it already has the lowered threshold for charging when grid voltage is low?
Hello!
Could you please check the actual grid input voltage in the app? Regarding the AC200PL, the voltage can be reduced to 55%, but we need to verify if it can go lower than half of the voltage.
If you have any further questions, please feel free to reach out.
HELP emerency
AC2P2352001159382 and AC2P2408000557259 - My two stations need your upload for 170w-200w! They are ALMOST empty but can’t take power less then 200w due to your initial settings. My fish is freezing. Help, please!
Hi Anne, if you add @BLUETTI_CARE or @BLUETTI to your post it will make sure they see it
Hi @BLUETTI or @BLUETTI_CARE, I’m from Ukraine and experiencing frequent E114 (Low Grid Voltage) errors on my AC70P due to unstable grid voltage (often around 180-200V because of the current situation). Standard firmware and Grid Self-adaptation don’t fully resolve it. Could you please provide a custom firmware with adjusted lower voltage thresholds?
Model: AC70P Serial Number: AC70P2510000377965 Current firmware versions (from BLUETTI app):
  • ARM: v2152.05
  • DSP: v2112.06
  • IOT: v9046.04
Thank you for your support!
Hello, I have registered your device for a firmware upgrade. Please wait patiently.
Hi @BLUETTI or @BLUETTI_CARE, I’m from Ukraine and experiencing frequent E114 (Low Grid Voltage) errors on my AC2P due to unstable grid voltage (often around 180-200V because of the current situation). Standard firmware and Grid Self-adaptation don’t fully resolve it. Could you please provide a custom firmware with adjusted lower voltage thresholds?
Model: AC2P Serial Numbers: AC2P2352001159382 and AC2P2408000557259
ARM v2137.02
DSP v2136.01
@BLUETTI can anybody solve my issue please :pray:
