Charging EB3A with dc
hello
I have an EB3A, can I charge it with the T200S AC ADAPTER?
EB3A: 12-28 Vdc, 8.5A (dc input)
T200S AC ADAPTER: 25.2 Vdc, 8A (dc output)
specifications match, 25.2 x 8 =201.6W , EB3A: 200W pv.
T200S can charge EB3A with alternating current.
Yes, you can use the T200S adapter connected to AC current but not sure why you would want to do so since the eb3a has a built in charger that would connect to the same ac source.
when the inverter is working, the output voltage is 230v, and the power quality is better than in the UPS option.
