Hi, is it possible and safe to charge the Bluetti with a simple gasoline generator without inverter or can the “unclean” voltage destroy the Bluetti?
Hi @mafussen , The following conditions must be met to charge our machines with gasoline generators.
- the frequency of the generator matches that of the machine
- the output of the generator is pure sine wave
The technical spec of the generator is:
Rated power: 5.0 kW
Voltage: 230 V
Sockets: 1x16A, 1x32A
ATS Connector: no
Frequency: 50 Hz
Maximum current: 32 A
Voltage regulator: AVR
Power Factor: 1 Cosφ
As @BLUETTI says above, you need to make sure that the generator outputs pure sign wave. If so then you are good to go.
I don’t know about Europe but in North America some cheaper generators are modified sign wave.
Thx… I have a Honda 2200 pure sine wave inverted petrol generator . CAn I plug that straight into the Bluetti AC charger and start charging?
Does the machine need to be in a certain mode?
Does the charger need to be turned after the 200max is
On?
Thx
Luke (australia)
