Charger 1 When Power Pack is Full
I have received my Charger 1 today but before fitting it I’d like to know what happens when the power pack it’s charging gets to 100%? Does the Charger 1 stop charging or do I have to keep an eye on the power pack charge level and then switch it off manually when it’s done? I ordered the cable kit which comes with an MCB which could be used to switch it on and off but I’d like to know if it’s safe to leave it connected all the time or not?
@Bazla
Once fully charged, it stops charging.
If the charging time (while the engine is running) exceeds 30 minutes and the 12V battery voltage drops below 12.4V, Charger1 will shut down. The circuit breaker acts as a protective switch—it’s fine to leave it on, but you can turn it off if preferred.
Thanks for clarifying.
