How many effective Ah does it have? Thanks
On the AC side, I was able to draw about 620 watt-hours from a fully charged EB70. If we “do the math”, that would be about 5 amp-hours @ 120 volts. I have not done a draw down test on the DC side but if we assume that it has a similar capacity, the capacity would be about 47 amp-hours @ 13 volts.
Thank you very much greetings
I got 615Wh discharging from a AC source at 150w. About 85% of rated capacity, which is decent.
