Hi @asgardsrei, we’ve checked and found that your firmware is already up to date, and there’s currently no newer firmware available to push.
For now, we suggest you purchase a voltage stabilizer to use.
Hi @BLUETTI_CARE . Welp, got same problem here, I’m from Ukraine too so i got equal problem with low voltage. Can u get me this data to solve this issue?
EB3A
s\n EB3A2435006209461
ARM v2118.09
DSP v2117.08
Hi, @BLUETTI_CARE
Got the same problem, as previous users from Ukraine - my station is not able to charge because of <190 Volts. Also checked for the new updates but application said that everything is up-to-date.
So, could you please share most recent fw with extended charging voltage ranges?
Thanks!
S/N: EB3A2236002875208
ARM: v2053.08
DSP: v2052.11
Hi @Katarsis, thank you for contacting us, I have applied to upgrade your system to our IT department. If the new firmware is available, they will complete the push within 24 hours.
Hi @crazyfox-ua, thank you for contacting us, I have applied to upgrade your system to our IT department. If the new firmware is available, they will complete the push within 24 hours.
Hi! I charge my Bluetti (AC50P and EB3A) from generator.
The generator issues 47-48 Hz (instead of 50 Hz).
Can the Bluetti be configured to charge with a lower frequency current?
Hi, @BLUETTI_CARE
Thanks!
S/N: EB3A2309011072602
ARM: v2063.03
DSP: v2052.11
@BLUETTI_CARE hi Bluetti team, same story on my end as I’m in Ukraine as well and sometimes the current is stable but under <190V. Could you please send an update?
S/N: EB3A2245003514991
ARM: v2063.03
DSP: v2052.11
Thanks a lot!
Hi @Katarsis, than you for letting us know.
Your feedback is very valuable to us. We have shared this good news with the technical team, and they are very pleased!
Hi @Fynby, thank you for getting in touch with us.
Hi @MadeinXTZ, thank you for contacting us.
In my Bluetti app, it says new firmware available. But, no download button showing. Please help me to update my firmware. Please see details below.
S/N - EB3A2435008190615
ARM - v2118.09
DSP - 2117.08
