Bluetti AC200P’s DC 12v / 3a barrel plugs x2…?
What are people using these available ports in a real-world use case…?
There is two of them but I have no idea what devices or setup would benefit from these ports.
Photos or comments greatly appreciated…
              Wifi routers or drone chargers.
              @SilicaStorm you can also use an adapter to turn them into a female cigarette port. Seen people use those for smaller dc coolers and even dash cameras.
[2 PACK] Cigarette Lighter to DC 5.5mm x 2.1mm Jack Adapter -12v DC Female Socket to 5.5mm x 2.1mm Male Barrel Plug Charger Cable for Portable UPS Battery Backup Emergency Backup Generator https://www.amazon.com/dp/B08R38KFXK/ref=cm_sw_r_cp_api_glt_fabc_M1QACJ2ZQVS39AC8HH8D
              LED lights or LED lighting strips are another common low powered use
              Hi @SilicaStorm,
Thank you for your question.
The two DC outlets on the front is DC5521 or DC 5.5mm x 2.1mm, which is usually compatible with some LED strip lights, security cameras, routers.
