Page 9 specs for the B230 battery says that the Expansion port is 58.8 volts 8 Amps. Seems way too low. I hope that it is a typographical error. Please confirm the real Amp spec.
It’s the same as the B300 which is 80A.
Thanks. I hope that they fix it sometime soon. Really surprised that a “sanity check” wasn’t done on it before publishing. Most people assume that the manual published by the manufacturer will be correct.
