Interesting. In order to reach 5000W with 2* B300, do you need 2* P150D to P090D ? Or is 1 enough as in the following ASCII diagram shows, connecting the B300 with their default cable?
Interesting. Especially since it seems that the self-heating feature is only available when the battery is connected to a grid, correct? Grid, or simply put, an AC source.
Sorry, I took a shortcut in my phrasing; I meant, since B300S needs to be connected to an AC source to benefit from its self-heating feature, it makes B300 more attractive in my case since I don’t have an AC source where I plan to install the AC500… so for a lower price tag, adding a B300 seems like a better option.
That’s been my thinking as well. My AC500 came with a B300S and since then I’ve added two B300’s. The only downside is if I wanted more than four batteries it wouldn’t work.
