It been a while since there has been an update to this thread so I thought I would give an update on how I am set up and using a protran 30A manual xfer switch while connected to grid power.
I have the two AC300 in split phase connected to the combiner box powering my xfer switch.
The xfer switch in only proving power to my 120v circuits in my home and garage.
The AC300 were having issues with the floating ground so I plugged in bonding plugs to one unit then the other. No noticeable difference if they are in one or both AC300s.
This seems to provide stability to the system when not connected to Grid power.
I used a dedicated 30A 240V plug and Bluetti cable to connect grid power to system. I started to get 025/026 errors. I then used an old 50A RV surge protector for input grid power. This seemed to have gotten rid of the errors.
The system has been stable since. It has been several weeks set up in that configuration connected to grid power.
During this time I have had the system set to PV priority with SOC at 15%. As the nights grow longer here I do find the system occasionally needing to use grid power to charge in the morning. It has been doing this well.
I will admit, my load my not be as great as many others and I am running pretty basic appliances.
But it does what I need it to do. I was able to work through the many problems with the help of the folks on this forum. So, thank you all.
My last complaint is the UPS as advertised is really working as an EPS (good luck looking that up- Bluetti calls it an "Emergancy Power Supply). Not what I thought I bought.
As I am understanding what Bluetti is telling me is that in split phase that they are an EPS in single phase they are an UPS. I see this is due to the combiner box.
I have considered bypassing the combiner box with a custom cable to xfer switch and set each AC300 in single phase to provide independent UPS solution on different phases to my xfer switch.
If I recall @twister36 may have started in this direction while waiting for the combiner box.
Please share your thought on this idea.
