I have a question regarding the two solar inputs. Are those actually totally independent inputs? Could I run two series arrays at 960w, 120v, 9.6a giving me a total of 2020w’s? Looking at the spec limits it says 150v and 12a. I would exceed the amperage limits if trying to run the two arrays in parallel, but if each input is seperate then I could just run them in series.
I’m answering my own question. I was able to find the manual and it states that the pigtail is basically two seperate mppt controllers maxing out at 1200w, 150v, and 12a each for a total of 2400w.
I also have the AC300 and I believe that it is the only one with two parallei PV inputs.
