Curious if the ac50s car charging cord work on ac30?
The cord will physically fit. Bluetti says it will not function…but…I would be willing to try it. I think that since the AC30 has no mechanism to boost the incoming charging voltage then lower voltages will not work and that is why Bluetti says car charging won’t work. I think that if the engine is running (driving) and the voltage is 13.5 or better than car charging will work. But that is purely my personal opinion.
Bluetti is correct. Car charging will not work for all practical purposes. You can get about 20 watts with the enging running and putting out high voltage. Not really practical for car charging. Only way to car charge is to use a small low powered inverter and then plug the AC charger into that
