Is there a way to use your car DC power to imitate 1200watt total solar charging capability on the Bluetti AC200P? I’d like a setup to use 1200 watt only while the car is running to charge.
thanks
thanks
@gigajoe Unfortunately, constant power output cannot simulate the variable power output of solar charging. The Bluetti AC200P is designed to handle up to 1200 watts of solar power, which can vary depending on the sunlight and other environmental factors. Using a car’s DC power to charge the AC200P at a constant 1200 watts while the car is running is not possible. However, you can still use the car’s DC power to charge the AC200P at a lower, constant rate.
