I am planning on hooking up an appropriate number of BougeRV 100W 9BB monocrystalline panels in series to the AC200P. I understand the AC200P requires input VOC of at least 35v. The panel “Tech Specs” say that the VOC is 21.4v for 1 panel, although it also states that each panel is “12V” in the description. I am confused by that?
I am new to using solar panels, so would just TWO of these panels in series meet the minimum requirement for the AC200P or would I need at least THREE in series (in which case I would purchase four as I am attaching these rigid panels in two’s together with hinges to fold them & make them portable)?
Here is a link to the panel: BougeRV 100 Watt Solar Panel | 12V Monocrystalline | 9BB Solar Panel
Thank you!
