I’ve owned recently AC200MAX and have several suggestions:
- I noticed that there is no pairing procedure during connecting smartphone to the AC200MAX. Also, I see my AC200MAX is discoverable via Bluetooth from the other devices such as laptops etc. Is there any risk that somebody (e.g. my neighbor) will connect to the AC200MAX and will turn on/off AC/DC outputs? I expect to have pairing procedure as most devices, which connect each other via Bluetooth, have.
- When I click on AC/DC ON/OFF buttons on the touch screen, the popup window is shown. It has ON and OFF buttons. Sometimes, pressing that buttons leads to activating ‘AC/DC ON/OFF’ buttons located UNDER the popup window. Maybe, a delay for ‘1 second’ should be added between pressing and disappearing of the popup window to get rid of the behavior.
- Touch screen does not show the load connected to AC output outlets if consumed power less than, I observe, 60-70W. It would be great to be able to monitor everything on AC output, like it is for DC one.
- I have already posted the problem related to T500 power adapter in the separate thread, but still think that it is very popular problem users have around the world. T500 is very noisy and does not turn off its fans when battery is fully charged. Please consider applying a bigger radiator inside it to get rid of the fans completely, or add small changes to the electric schema to turn off the fans, like LED changes its color from RED (during charging) to GREEN (when 100% reached).
