AC200L or Elite 200
Trying to decide between these two units coupled with the alternator charger.
I am going to use this for SUV camping, and maybe UPS for PC in between trips to keep battery in use.
AC200L Benefits Expandability (though I don’t know if I will ever add more batteries, nice to have). I believe faster charging, more mature product. Higher solar and AC charging. 100% LESS LIFE CYCLES?
AC200L Detriments bigger form factor, 9 lbs heavier, $100 more when coupled with charger.
I was leaning towards the 200L for the expandability but based on the life cycles the Elite 200 makes more sense.
Trying to get this done today. Any suggestions appreciated. TIA
@Crozroads
You may find the following posts helpful as reference:
I was all set to acquire a 200 Elite but have had a re think based on voltage difference. I have heavy use requirements and can find no way to completely recharge the Elite in a single day of optimal sun without going over volts or amps. My space is limited, so no way can I run 5 200W panels. One the other hand, the AC200 has 145 volts and would lend itself to connecting 2 450W panels in series without going over voltage. Another great feature of the AC200 is it superior in surge capacity for motors that initially draw a lot of power as they start.
