AC200
Hi All
I have just noticed multiple errors on my AC200, 6 Pages total. What should I do, Stop using straight away ?
Must be some computer error Can’t have over voltage and low voltage of the same item at the same time.
@AnthonyS No problem with it. Please pay attention to the dots behind it. When the error appears, the dots will turn yellow to remind.
This is just an index of possible fault codes. Unless the dots are yellow as mentioned by Bluetti, there is no fault code registered.
