Adide from the AC180P, could you please include the AC180? Pretty please?
Я сегодня обновил AC180P,это прекрасно что наконец то появился это пункт в меню,по восстановлению AC,тоже жду обновление для AC200PL.
Заранее благодарю
Hi @Jayar, We’re happy to inform you that we’ve now developed a new firmware for the AC180 that allows it to save both AC and DC output settings.
Please let us know your AC180’s SN code and current firmware version, and we’ll push the update to your unit.
Hi @Pletenets, Thank you for the update. We’re glad to hear that the new firmware for the AC180P is working well.
Regarding the AC200PL, we’ve already forwarded your request to the relevant team. We hope they can release the new firmware as soon as possible.
Hi @BLUETTI_CARE Id be keen for this feature!! its one of the cons for the AC180 for me that after the unit has run out of power and the charger 1 recharges some power the AC180 turns on but it doesnt remember DC state to on after it ran out of charge i have to manually remember to turn on the dc again :(
@BLUETTI_CARE Hello, totally agrreing with previous author, but for the AC200PL, any news on that?
Thank you.
Hi @bluetti_rachelgreenlinkwebau, The AC180 now has new firmware available that enables the “remember output Settings” feature.
If you would like this feature, please provide your AC180’s SN code and current firmware version.
Please note that after the update, this feature will be enabled by default and cannot be turned off.
Also, please note that AC output will only activate when the battery’s level more than 5%.
- When grid power is available, the output settings will resume as soon as the battery reaches 5%.
- When grid power is unavailable, the output settings will only resume if the battery reaches 5% and the output has remained off for at least 30 minutes.
Additionally, if your Bluetti app has been updated to version 2.3.10, you’ll need to input the password 88888888 to enable this feature.
Hi @snmya, Thank you for your attention to BLUETTI.
We have once again urged the R&D department regarding the new firmware for the AC200PL, but we have not received a response yet.
Very nice feature to have, finally ![]()
Confirmed that its working on AC180P - “When grid power is available, the output settings will resume as soon as the battery reaches 5%”
IoT v9046.01
ARM v2125.04
Hi @BLUETTI_CARE ,
I had the system switch recovery added to my AC70.
It works as it should, there is no problem, but I have 2 other Bluettis now that have the recovery feature where it can also be turned on and off via the app, so I don’t need it on the AC70 anymore. When you added it previously you said it could be removed by reverting to the previous update status of the AC70. Please could you do that for me?
Thank you.
Hi @Tezzabee, We have consulted with the technical team regarding this matter and learned that the function can be turned off via the app instead of rolling back the firmware, which is more convenient.
Would you agree to this solution? This approach can avoid potential risks of firmware rollback and save you time. I hope it does help.
Hi @BLUETTI_CARE ,
Thank you for your reply.
I don’t currently have the facility to turn the function off in my app. Is it the upgrade to IOT that is showing in my app today that will enable an on /off function?
If so I would be happy with that.
Will my AC70 also be able to receive any batch pushed upgrades after that please, as currently it can’t.
Thanks for your help ![]()
Hi @Tezzabee, You are welcome, it’s our pleasure to help you. :)
Please confirm that the AC70 is correctly bound and connected, not via Bluetooth direct connection. Meanwhile, please confirm your Bluetti app is the latest version.
Then navigate to Advanced Setting and turn off the System Switch Recovery function. We have attached a screenshot for reference.
Note: The password required is 8 consecutive 8s (88888888).
Rest assured that this operation will not affect subsequent batch firmware pushes. We have no plans to push new firmware to the AC70 shortly, but if we do, you will receive a notification and can update normally.
If you need further guidance on the steps or encounter any issues, feel free to let us know!
Hi!
I own AC180P, used it for a year, and bought AC200PL a month ago. I was shocked in a good way that you added this feature to AC180P. I thought that kind of stuff was impossible.
But could you please tell the boys at the R&D department to hustle up a bit so they add this to the AC200PL models too?
Given the way things are going here in Ukraine, we’re probably gonna use your products as 24/7 UPS again soon.
Thanks!
Привіт.
Також підтримую за модель 200pl
Дуже чекаю
Hi @VSM and @Pletenets, Thank you for your attention to the AC200PL. We have forwarded your suggestions to the R&D department and hope they can complete the relevant work as soon as possible. This may take some time, as the newly released models recently have a high demand for new firmware, and this requirement may be scheduled later.
We understand your expectations for the product and will keep following up on the progress of this matter. If there is any new information, we will inform you in time. Thank you for your understanding and support!
@BLUETTI_CARE Hi!
I kindly remind you, that this functionality for AC200PL was requested 6 months ago in this very topic, and was requested in other topic even before that. Plus, as it was already implemented for AC180, there should not be a lot to research and develop for this feature for a similar model.
_
A lot of customers are waiting for it, so saying it’s not a priority is a bit harsh: if support for products that were released a mere 1-2 years ago is cut out, then this makes customers reconsider buying new ones too: we are concerned, next year something new will come out and current product will be neglected regarding updates and fixes.
Thanks!
Hi @BLUETTI_CARE ,
I have installed the IOT update. My app was also recently updated. I still do not see the system switch recovery in advanced settings, only AC output frequency and Grid self-adaption. This is an AC70, not AC70P, in case that makes a difference. A special update was done some time ago via this forum thread. I was told at the time the update would mean the AC70 would not receive normal updates after that, and that the feature would be ‘always on’ , but the update could be removed in the future. It is bound to my account.
Hi again @BLUETTI_CARE , I have copied your previous posts for easier understanding, I hope this helps ![]()
Hi @Tezzabee, Yes, we have received the message you sent yesterday. We already requested the new firmware for you yesterday.
However, we apologize, as the engineers informed us that the new firmware is currently only available for certain batches of the AC70P. The new firmware for the AC70 has not yet been fully tested, so it may take some more time.
We have urged the product development team to push the firmware to you separately. We have received a response, and they said they can push the firmware to you. However, the firmware is still not fully mature, and once pushed, this feature cannot be turned off. Do you agree with this? This could potentially create certain risks. For example, if you’re boiling water before a power outage, enabling this feature would allow it to continue boiling when power is restored, without needing to be manually turned on, which may result in an unmonitored situation. Once confirmed, we will push it to your AC70.
Hi @Tezzabee, We have urged the technical department to push the new firmware ARM v2751.71 again.
They informed me that this new firmware is temporarily incompatible with other new firmware. After upgrading to this ARM v2751.71, your AC70 will not be able to receive other batch-pushed firmware.
However, if you need, we can help you revert to the original firmware, and then you will continue to receive other new firmware updates.
Hi @Tezzabee, Thank you for getting back to us so quickly.
We have pushed the new ARM2751.71 to your AC70, you can upgrade it whenever as you wish.
Due to the limited number of similar customer requests, it is unlikely that we will have other batch-pushed versions in the near future. I’m afraid we cannot provide you with a specific timeline.
NB this was the AC70’s firmware prior to the update:
AC702427000781008
IOT V 9046.01
ARM v 2151.01
DSP v 2106.06
Hi @Tezzabee, Thank you for your feedback.
We discussed this matter with the technical department, who found that the new firmware for the AC70 wasn’t properly compatible with the latest app version. That’s why you can’t find the button to enable the System Switch Recovery function.
We’ve urged them to finalize the compatibility promptly, and it will be available in the next app update. Please upgrade your app by then to access this feature.
I appreciate your kind understanding and patience.
