I have now received the replacement AC180. I ran a full set of initial tests: physical inspection, Bluetooth pairing, firmware/BMS update, light load test, and a complete recharge to 100%. Everything is working properly and stable so far.
I appreciate that Bluetti replaced the unit, but I will continue monitoring the performance over time, considering the failure of the first unit. Hopefully this one will prove reliable in the long run.
