Bluetti your input please…
using two of your future 50 amp units sharing feeds for a panel >>>
- there is no potential difference on what you would consider the “neutral” side and they can be Siamese together without issues?
- guessing these will be floating neutrals how will you address the neutrals with respect to the NEC and grounding at the first means of disconnect?
Thanks in advance
