220max sleeptimer
Hi all. New to my Bluetti. It has a function called sleep timer.
that can be set to 30 sec 1 min 5 min etc (or never)
but what does it do/switch off etc. what dies it put into “sleep”. TIA
It is just the amount of time the touch screen display is on. If you have it set to 30 seconds, it will turn off 30 seconds after you have touched the screen last. The system stays on regardless. You can tap the screen and it will turn back on.
