12v/30 aviation outlet
Looking to get the cable for the aviation 12v/30 outlet. Understand that it will not be available till june anyone have any ideas on how to get one or make one?
@Tomtom Here’s a thread with some listed links to how you can make your own…
@Tomtom Just make sure you get the “WEIPU” brand SA20 2-pin aviation plug as the other branded ones will not plug into the AC200 models
Thanks . I have the bluetti max do you think that the aviation plug on that model would be the same as the 200?
I ordered one .guessed they probably use the same connector. Thanks for your advice.
Yes, The AC200Max uses the same WEIPU SA20 2-pin aviation plug.
I ordered it. Coming from China i see. Should be interesting how long it takes with all the problems we are having.
Not al Weipun SA2 plugs are the same. They also have indentations at various locations on the round plug side. I had a couple from China that had those at the wrong location, so I just ordered the official ones from Bluetti in the end.
Mine came in this week. Same problem will not fit. Will order one from bluetti.
