Wrong Wattage Display EB3A
Hi, i use the EB3A in powerlifting mode with a nespresso machine which works ok so far. But the power display on the display and app are incorrect. The machine consumpts around 1.300W and the display says only around 300W. Could it be that the display just cant show values with 4 digits? But that would not explain why the reading is also wrong in the app.
You are indeed seeing the correct output wattage. When in power lifting mode, the wattage is limited and the voltage is reduced in order to not overload the EB3A. You do not get increased wattage by being in power lift mode and actually a reduction from the max output of 600 in normal mode.
Hi @Danny78, I agree with @Scott-Benson’s opinion.
When you select the Powerlifting mode, the voltage will be reduced to accommodate purely resistive loads that exceed the normal ability. However, please note that the Powerlifting mode is specifically designed for purely resistive loads with a maximum power of 1200W. Loads exceeding this limit may not be supported.
