Hello. I see that power output is 154 watt but at the same time I see that current draw is 1.1 amp at 230 volts which means that overall power should be 230 x 1.1 = 253 watt. Is current data wrong?
@Kvano The charging power is active power within 200W, and the apparent power will be displayed when it is greater than 200W. The displayed current is the apparent power current, and the actual displayed current is the active power.
