So it works for 5 min then stops. Removed case still same. No updates available per app.
Anyone find a solution. Only reason I bought this was for that function.
You don’t mention which Bluetti you have, but, if applicable, check your Eco mode settings or turn it off as this might explain the issue. Depending on the settings, Eco mode may turn off the output if there is little or no draw.
Ok it’s the small one. 280 something watts. But I think I figured it out. Need to test more. Seems to not want to charge wireless when charging the system. All unplugged charges fine. Odd.
