Will a Typ A RCD work ok with a Bluetti 500W Adapter?
Some car charging systems require Type B RCDs because smooth DC current can “disable” a normal Type A RCD.
Does this problem exist when using the 500 Watt AC adapter for charging an AC200P, or will our Type A RCD/RCBO(GFCI) function OK with the Bluetti adapter?
Thanks!
@Daver2 After confirming with engineers, the two are compatible.
