Where to connect the +-connector of the Charger 1?
Hi,
See attached picture please.
For the-side (negative) I only have one option to connect the Charger 1.
Which nut/bolt of the +side (postive) of the battery can I Use best?
My vehicle is a Citroen Jumper (Relay, similar to Fiat Ducato and Peugeot Boxer).
TIA.
Kind regards,
Christophe
@ChristopheL69 If these are all positive terminals, then they can all be connected.
Hi,
They are all positive connectors but I was wondering if one of them was more interesting to use because it’s connected behind a fuse (for extra security).
Kind regards,
Christophe
The essence of these connectors is the same, with no distinction between good and bad; they are simply designed to fit the size of the terminal. :)
