I bought my AC300 two days ago (from Hornbach in Czechia, EU) and now running it in the custom UPS mode (60 low - 90 high, no times set).
Grid input shows as 50Hz, input voltage as 244V.
AC output shows 244V, 50Hz, ~ 200W. State: Bypass output - D.
Battery status now shows as 98% - Standby.
Normally, Grid watt input is about AC output + ~5W. My current regular AC output is ~200-300W (home office).
Tried both silent mode or no silent mode.
What happens to me is that about every minute, AC300 clicks loudly and switches to 0 watt Grid input, then within 2 seconds it clicks again and goes back to AC output + ~5W. AC output seems to be not affected by this grid wattage switch - AC output runs continuously.
What bothers me is that loud click and not understanding why it needs to switch relay to go to 0 only to click again in 1-2 seconds and go back to regular grid input.
If I use the Standard UPS mode, the situation gets worse:
Instead of clicking and going to 0 grid input every minute - it oscillates the charge state between 100% and 99% every minute and on reaching 99% - it clicks and goes charging up to 2kW for a short period of time (several seconds) then clicks and stops charging, returning to AC output + ~5W. And it does it every 30 seconds - 1 minute.
I have all the latest firmware updates for all components. Eco mode if off.
This can’t be the intended way of how it should work?
My Serial number is AC3002250000078868
Communication board SN: IoT2243007373202
I tried switching AC output off/on and restart. Tried switching between UPS modes. None of that helped.
Is here anything else I can try while creating a ticket for Bluetti and waiting for their response? If I get any information from them, I’ll be sharing here.
Thank you!
