What is the best way to recharge the B300 battery, with the aim of extending its lifespan?
Do I charge the B300 with the lowest possible current, for example 3 amps? The higher the current the warmer the cells get, so with that in mind, do I go with the lowest possible current?
On the other hand, the voltage remains higher for a longer period of time, which may also be less desirable for the cells?
- Avoid drawing too much charging power, standard charging is fine. Only use fast charging in emergency situations, as this better protects the battery.
- Also, don’t overdischarge too often, timely recharge the battery.
- We have a BMS system that protects the battery, so there’s basically no need to worry.
