I just recently bought a Bluetti ac180 solar generator.
What happens if a 200 watt solar panel generates 11 or 12 amps with a Bluetti 180ac? A lot of the solar panels available are 18 to 19.9 volts which will generate over 10 amps. I am trying to look at panels that generate 20 or more volts. Bluetti’s panel are not completely waterproof and I like to go to star parties, we have in the past been hit by surprise thunderstorms at the NSP in particular. Also at the Iowa Star Party.
Your ac180 self limits the incoming amperage to its maximum limit. Your panels can generate more than that limit but the 180 will only allow the set amount incoming. No problem.
Hi @thaimann
Amps are not the problem. The A180 just pull a much as needed. The value you need to pay attention if is voltage. This gets “pushed” from the panel to your AC180. If your overvoltage the MPPT, the risk to kill it forever is really high.
