Video: hot-swapping AC180T under 1kW load
AC180T is boiling water (940W AC) and running the Multicooler on Turbo (50-60W DC) as I test hot-swapping a B70 SwapSolar battery.
AC180T simply and casually updates the display to match the new capacity, and projected lifespan.
Splendid engineering there!
Each battery can deliver up to 1200W, and the load balancing seems instantaneous.
Kuddos @BLUETTI :fire::blue_heart:
Nice test, thank you! Well done Bluetti!
Just finished another test, 1185W and smooth as silk!
Push those limits! :grinning: :+1:
I didn’t hot-swap at 1300W since it’s above the advertised limit (and the kind reminder in the battery compartment), but I tested a 1300W load on a single battery. It didn’t trip, or even shout. At 1400W, after about 10s of overload alert, the system turned AC off.
That’s quite impressive for a single battery.
