Hi everyone,
I recently received my new Bluetti Elite 30 V2. It’s a fantastic device, but I’m experiencing a very frustrating issue regarding the Bluetooth connectivity.
After about half a day of use, the Bluetooth icon suddenly disappears from the display. The strange thing is that when I check the settings (P6), Bluetooth is still marked as “ON.” Even if I toggle it OFF and ON again from the menu, the icon does not reappear, and it’s impossible to connect via the app—the signal seems completely dead.
I have already installed the latest firmware update, and I’ve tried turning off all other Bluetooth devices nearby, but nothing helps.
The only way to restore the connection (and it doesn’t even work every time) is to perform a full “cold” restart: I have to shut down the unit, physically disconnect the solar panels, wait a few minutes, and then turn it back on. Only then does the icon usually reappear.
Is anyone else facing this same bug on the Elite 30 V2? I hope Bluetti releases a firmware fix soon, because having to unplug everything just to regain app control is unacceptable for a high-end machine like this.
Thanks for any help or advice!
Device Information:
- Model: Bluetti Elite 30 V2
- S/N: EL30V22605211847549
- Communication Board S/N (IoT): IoT2604511168775
