Validate configuration. Managed to get myself confused
I have recently purchased a bluetti ac200l, d40 and renogy 100w lithium battery (replacement house battery).
I have things configured as follows:
solar on rv wired to solar input of ac200l
d40 connected to port on ac200l - input
d40 connected to house battery - output
house battery connected to main positive and negative inputs as old agp battery
This seems to run my 12v load just fine. When i want to power the 120v outlets i turn off the onboard converter and then plug the rv shore power into the ac200l and that runs everything including my heater and ac and all of my other 120v needs (tv etc.)
Question: is my configuration / logic ok? With this setup will i take full advantage of the capacity of the ac200l and house battery?
Thanks in advance for reading and feedbacl
@RasDog
Your setup looks fine—feel free to proceed with the wiring. :blush:
Thank you for confirming
For clarification,is it acceptable to charge house batteries with ,ac200l,d 40,and original converter when connected to shore power?
