Using Hub D1 Power Hub with B300s batteries
I am upgrading my AC500 to an Apex 300 and will be using my 6 B300s Expansion Batteries. I purchased the Hub D1 Power Hub to suppled needed ports to the system, but I can’t seem to insert the plug into the last B300s in my series.
Do I need a special cable to use the D1 Power Hub with a B300s or does it not work with that model of battery.
Ken
Hello, APEX300 and B300S connection requires P090D-P150D
Thanks. Is there a way to connect the D1 Power Hub to a B300s Expansion Battery?
Uploading: 回复.jpg…
Hello Greyboar - Did you find an answer? I’m worried that this isn’t possible because the Hub D1 and B300S expansion battery both connect to the same port on the Apex 300…
