Usage warnings
It would be handy to have a setting for excess usage over a set period. Eg If you accidently leave the hose running and the water pump runs longer than 30 minutes, it would be nice to have a warning rather than waking up without power during the night.
@RodSmith
Are you referring to the low battery alert when BLUETTI is connected to the app? May I know what’s your BLUETTI model?
I have the EP76 with two batteries. I would like a notification of anything that has a constant current draw above a certain amount (adjustable) as a rminder to turn things off before I use all the battery capacitiy.
Eg if I forget to turn off a device. (like a pool pump)
