"Upgrade" not update
NEWBIE
Hi,just received my new elite.V200…There’s a new version upgrade (not an update) ARMv2185.08 → v2185.09 and DSP,BMS etc…I have updated the Elite but not sure what the upgrade is? Thanks for any help!
Hi @Panda, It seems you have successfully completed the upgrade, and you want to know what parts were upgraded, right?
The new ARM v2185.09 firmware has added the Sleep Mode function, fixed the issue of fan flickering, resolved the problem where Bluetooth and WiFi icons didn’t display after the upgrade, and addressed the instability of solar charging power.
Hope this helps.
@Panda Does the answer from @BLUETTI_CARE cover your question? Or do you mean what the difference between a update and upgrade?
Yes and No…When I searched for the difference an Ai bot went off on one stating it was not the same for the ELite 200 that I had purchased the other day…so I joined you guys and got an email which I responded and thanked the Moderator personally by return email…The Moderator listed the update…no upgrade:) I like to check when I update any product I have ,as in this case I could not see/find what what the update was for…I have a home 9.5 battery with roof solar and several updates in the passed have caused more problems than they have solved so I like to know what’s what if you know what I mean. I am now looking for a protective bag for my new Elite v200 and a light weight trolley can’t seem to find them either at the moment…It’s not that I can’t lift it but anything to make life easier :)
Ah. i get it. Update the Bluetti unit can bring new features or bug fixes. The App mentioned everything as “upgrade”. No matter if its a small update or a big feature upgrade
Hi @Panda, Thank you for the update. It seems that you haven’t performed the upgrade, have you?
If you need to know which specific version has been upgraded and what content has been updated, please provide the specific version number so that we can check it for you.
In addition, if you encounter any problems during use, please @BLUETTI_CARE.
Thanks to @Selfmadestrom for their concern and help with this matter.
After i upgraded to the latest, it no longer charging the unit via Grid, as of writing, I do not have solar pv.
Here is what I have:
ARM - V2185.11
DSP - V2184.06
BMS - V1068.11
What are the step should I do to solve the charging issue?
Hi @pbmac, could you please provide your SN code for further analysis of the issue?
We suspect this might be related to the default settings. Could you try switching to the Standard UPS Mode and testing again? Do you think this will help resolve the issue?
