I have the bluetti ac200max being charged by three 220 w panels , in full sun at noon I’m only getting about 198 max watts , I have them hooked up in parallel is this correct or have I got a problem ?
@bluetti_pizzutiboisvertgmailcom Because you connect the solar panels in parallel, the total power will not increase.
If you three solar panels open circuit voltage added up, not more than AC200MAX rated maximum, it is recommended to connect in series, power will increase a lot.
