Have you drained the 200 max under a good load until the battery is empty and then recharged to full immediately afterward? If not, I suggest giving that a try to re-calibrate the state of charge estimate.
Hi @mmul, I agree with @Scott-Benson’s opinion, please calibrate the AC200MAX, it does help to resolve this problem.
Meanwhile, can you tell us the SN number and BMS version of your AC200MAX? We will check if it is the latest one.
