The station is charged to 100%. When the light is turned off, even with a load of 5w. within a minute the charge drops to 97%, then discharges normally according to the load. Why does 3% of the charge go away instantly?
Hi @Saulus, We found that your firmware is already the latest version.
We suggest you do not turn on the AC and DC output if you don’t use the AC180P, which could reduce self-consuming watte.
Meanwhile, please try to do a complete cycle of discharge and charge to correct the SOC.
Please discharge all the power (charge AC & DC appliances with the power station till it is out of power and turns off automatically);
Please charge it again, please do not load any device when charging it, and do not interrupt it while in charge.
Once the power is 100% fully charged, turn off the machine, and leave it for 3 hours till it is cool down.
