Support for AC2A Error Code E074
Hi @BLUETTI_CARE,
The service ticket number is 392615.
I would appreciate your help with this case.
Check Detailed Error Code: Open the BLUETTI app, tap the SOC icon Battery Information Pack1 to see specific BMS error codes (like P003 or P051).
Restart the Unit: Power off the unit fully (hold the button until the screen goes blank), wait 10 minutes, and power it back on.
Allow Cooling:If the error happened while running heavy loads, let the unit sit for an hour to cool down before trying again.
Firmware Update Check in the app for any pending firmware updates, which can resolve bugs causing false alarms.
If the error persists, it likely indicates a defect requiring service
Hi @cofb041, thank you for letting us know.
We found that you placed your order on AliExpress, is that correct?
We have provided the details to the seller and urged them to prioritize your issue.
Ktt’s kind advice is very helpful!
