Suggestion regarding cool temp warning and the app
Hello bluetti team, i have noticed that bluetti doesn’t have a feature to limit how much you want bluetti charge to be while in Ups mode it will charge to 100 percent and i cant limit it but when the temp warning shows up battery charging stops and only pass through features continue working until device cools down and i unplug and reconnect again, cant you put this temp warning in the app so we can turn it on manually so battery charging stops or update the app using this to implement this feature i am not sure how limited you are hardware wise since technically limiting charge percentage feature is not included in bluetti eb3a to extend battery life span but i believe that manual temp warning in the app can be used this way. Thank you in advance.
I would love to have charge limit, pushing 100 constantly is surely not good for the battery life, i understand that dc still using battery and even with stopped charge it will still drain the battery slowly but i believe including minimum charge can resolve that as well.
