Are the mounting holes at the top and bottom of the SP200L panels capable of holding the panels 20 lbs for fence mounting (top holes with hooks and the underside of the panel would be resting on angled boards against the fence as a support). Four hooks along the top of the panel would be used. Nothing in the manual discusses those metal grommets at the top and bottom of the panel. Any insight would be appreciated.
If you are going to hang the solar panels for use on the fence, you need to secure all four holes above and four holes below.
Be sure to utilize all four holes or you will damage the panels.
thank you for the comment
