SolarX 4K Expansion
Could 1 Solar X 4k be connected to 2 apex 300 with 2 P090D pigtail cables? Each apex will also have a B300K attached to it. I realize I could switch to XT60 cable but that cuts my power output way down.
Currently have 1 apex 300 1 B300K 1 Solarx 4K 1 P090D cable and 4000 Watt Soar array, looking at options to expand.
Hello, it can only be replaced with an XT60 connector.
@BLUETTI If I have two or three Apex 300 connected through a Hub A1, will the SolarX 4K charge just one of them through the P090D cable, or all of the Apex 300 and batteries that are connected? I’m asking because I recently discovered that the Hub A1 causes them to all share the same 48v bus on the P090D/CA90 connectors.
Thank you for your inquiry. Please note that the device can only charge a single unit at a time. If you wish to charge three devices simultaneously, you will need to use the XT60 port, but please be aware that this will reduce the power output.
If you have any other questions, please feel free to reach out.
@BLUETTI Thanks. Then suppose that I have two or three Apex 300 connected through a Hub A1. Can I charge two of them at the same time with a single Charger 2 by connecting the Charger 2’s Power Station Output to one of the Apex 300, and the Bluetti Product Power Port to the other Apex 300?
From what I have read, you need a Solar X for each Apex 300.
This is correct.
I currently have 2 apex 300’s and only one Solar X. I need to get another Solar X.
