I have the same issue that someone else had with SolarX 4K and AC300. I believe it needs some update direct from Bluetti. Everything is up to date as far as I can do, but will only charge battery when it’s disconnected from the AC300.
Hi @Ulls, we would like more information about the issue. Could you let us know how you connected these devices? Have you already contacted our support team? If so, please tell us your service ticket number.
We also need the SN codes and current firmware versions of your AC300 and SolarX 4K.
Hi @Ulls, thank you for your update.
We have located your email and plan to push a new firmware to fix the issue for you.
Please check our email, provide the corresponding firmware version, and we will apply for the new firmware push.
