Everything is plug and i have only a input voltage between 25v and 26v but nothing else so the solar panel dont charge
No input current, no input power, no generatio energy.
I try to charge it with the adapter and it work.
Can somebody help me please
Hi William,
Welcome to the forum!
Few questions to begin with:
- what solar power generator do you have?
- what solar panels do you have? Model reference, or pictures of the label will do (with voltages, design power, “Voc” and all)
- how did you wire the panels? Series, parallel, how many…
- Do you have other test hardware (panels, generator) ? This to compare the results, and ensure that your sunlight conditions, exposure, angle of your setup.
Also, let us know if you did any voltage test (multimeter).
Thanks for the fast reply
- i have the ac200p for solar power generator
- i have the renogy 175w flexible solar panel 1X
I did not the the solar panel on a other device but the power station charge when i plug it with the wall adapter
When i plug only the adapter for the solar panel i have ~25v as input voltage but no input current, no input power, no generation energy
Referring to the manual, the solar input voltage is too low.
You should put a second panel in series / or replace your panel for a higher voltage, or use a DC050S Charging Enhancer.
I correct and complete my answer. The manual also indicates a car charging mode that accepts an input voltage of 23V-28.8V.
If you preferably configure it on “CAR” instead of “PV” , maybe it can work. But I don’t know in this case if you have the mppt.
