I have a camper van that I have converted, and have 360W of Solar panels, hooked up to 2 150 Ahr Lithium batteries. With all the necessary bits in between including 3000 Inverter.
I got to thinking, why not effect a similar Home back up system that would kick in during any Outages. So Bluetti came to mind.
I did some research and ended up purchasing the AC500 with B300S & Panels recommended by Bluetti PV350. Now bearing in mind that this is to be installed at my home permanently , I would intend to fix the Solar panels outside in a permanent position to collect power as would be expected.
It was only when unpacking the PV350, that I read, in the instruction manual that came with it. These Panels must not be allowed to get wet !!!
So, I am completely flummoxed.
If not in an external location, susceptible to wet weather, then where else would I be expected to place them?
So, as a newbie to Bluetti, I thought I would threw it out to more experienced users.
I would appreciate any feedback as to how anyone else has handled this.
Regards
Gents
