Solar panel SP200L - parallel versus series
With the Elite 200v2 with 4 SP200L panels, it is within specification to run two sets of two SP200L solar panels in parallel with the Elite 200V2 (2 panels in parallel connected to each side of the multi-connector for a total of four panels).
Basically two panels in parallel per branch times 2
thanks in advance for any guidance offered.
@Boboso52 No problem. The Elite 200 V2 is with a Y-type cable. There are two sets of MC4, and you can connect 2*SP200L in series on each set of MC4.
Hello Bluetti Admin,
Can you specify if the Elite 200 V2 has two independent mppts, each limited to 10A or a single mppt limited to 20A? thanks in advance.
Is attaching two sets of two SP200L to the Elite 200v2 in parallel also acceptable? Parallel wiring helps me avoid some shading issues.
Elite 200 V2 has only one MPPT channel split into Y-shape. :)
I would recommend connecting the solar panels in series.
So effectively, two sets of SP200L (20.52v) in series would deliver 41 volts at the Elite 200 MPPT connector….
